by JmanEspresso on Wed Jan 27, 2010 2:14 am
Hey,
I owned a Bunn G2 Bulk grinder for 8 months. I JUST sold it 2 days ago to fund another espresso grinder. I'll be 100% honest here.. It was hard to sell the G2. Meaning, I didn't want it to go.. But, the end result was worth it. Had I not just bought the Vario to handle brewing grinding, I wouldn't have sold. Now, dont get me wrong, the Bunn puts any home use, or any espresso grinder to absolute SHAME when it comes to brewing grinds.
It flies through a pound of coffee in under 30 seconds(about 27-28). The result is a incredibly consistent, cool, DUST FREE grind. The sweet spot is in the "auto drip" to "pourover drip" area. The real coarse presspot grind wasn't AS perfect.. but again, dont get me wrong, it was better then anything Ive seen.. and compare with the grind coming out of a Malhkonig Guatamala.
The Bunn G1-2-3 grinders are all the same thing. The number designates the size of the hopper in pounds. I used mine as a "per-pot" grinder.. just adding my 50grams or so at a time.
The grinder itself is built like a tank and heavy. There is nothing to break on the grinder, and the amount of coffee held in the grinder is a couple grams AT BEST.. The burrs are mounted vertically, and the coffee falls right out of them.. Meaning the retention is minimal.
This is your best bet. A home espresso grinder, like the rocky.. is a joke for what you need. Even a mazzer mini, or something similar would not even be able to do what your asking. None of those grinders can grind for very long without being turned off. Plus, they're just not suited to do what your asking. If you have a budget of $350, and need to grind 6lbs at a time, every other day or so.. This is the grinder you need.
They sell on Ebay for anywhere from 100-400. I sold mine for $350, which was a steal for the person who got it, as it was only used in my home, and in superb condition.
Call EspressoParts.com.. They sell the Burrset for the Bunn G series. Ask them what the burrs are rated at.(pounds wise). These grinders are meant to withstand the abuse of a SuperMarket, where people come in, take their couple bags of flavored, burnt coffee, and pass it through on Turkish so they can use it in their Krups "expresso machine". There is nothing a good cleaning, and maybe a burr change cant fix on these bad boys.
So, try to find one for a price that will allow you to put new burrs in. When it comes to used Grinders, especially ones which were almost certainly used in a Commercial Environment, You should expect to change the burrs. Changing the Burrs on the Bunn is pretty simple, the front dial comes off, then the grind-size plate, and then your in the burr chamber. unscrew the old ones, screw in the new ones. When you're putting it back together, just don't force anything/use common sense, and you should be fine.
