by ziobeege_72 on Tue Apr 13, 2010 6:40 pm
James is absolutely right in pointing out that not all Twists have problems, so by no means would my experience be yours. Most likely it wouldn't be. But I just wanted to let you know my experience so I should expand on this a little further
More specifically, my issues centred around two things; 1) having the trigger 'sticking' after a shot pull, therefore expending all the gas and 2) slow leaks even when the trigger did correct itself, using the recommended sized canister.
I contacted Mypressi who admirably admitted that they had some quality control issues around the Twists, particularly on certain batches manufactured before Christmas. This may well be on UK batches only - which I suspect you may also be sourcing from given where you are based. However their response and promised resolution has impressed me, and I would have no hesitation recommending the Twist. I would just wait a while, or at least ensure that the initial QC issues have been cleared if you wanted to get one now.
