Mazzer Super Jolly vs. Compak K10 WBC - Page 4
Postby Ken Fox on Tue Jul 14, 2009 9:07 pm
All the cracks are similar in shape and in location, which suggests to me either that some sort of stress is being transferred to the mini hoppers, which exceeds the strength of the plastic in this area, that the fabrication of the plastic mini-hoppers is flawed in some way, or that both of the above are true.
ken
What, me worry?
Alfred E. Neuman, 1955
Ken Fox
Postby cappadoc on Tue Jul 14, 2009 11:18 pm
Can anyone measure their K10 with the mini hopper for me, please?
Jeff
cappadoc
Postby fredfal on Tue Jul 14, 2009 11:39 pm
I don't think this is limited to the mini hoppers. I'm on my second regular sized hopper for my WBC and it's cracked -- just like the first one. The crack doesn't seem to be getting any bigger, so I'm just living with it for now.
-Fred
fredfal
Postby Sebastiaan007 on Wed Jul 15, 2009 4:59 pm
cappadoc wrote:Can anyone measure their K10 with the mini hopper for me, please?
Jeff
50CM high Jeff
I barista, do you?
Sebastiaan007
Postby da gino on Thu Mar 08, 2012 9:47 am
On a K10 PB/WBC, what should the outer diameter for an alternate hopper be where it inserts in the throat if one were to look for an option other than the mini one that some have had crack? (I assume this is the grinder's throat's inner diameter minus a tiny bit).
On the SJ a standard canning funnel works perfectly, but I think the throat on the K10 is supposed to be smaller.
da gino
Postby JohnB. on Thu Mar 08, 2012 10:03 am
The OD of the K10 small hopper "neck" is 47.5mm at its widest point. This gives a snug fit in the K10 throat.
LMWDP 267
JohnB.
Postby da gino on Thu Mar 08, 2012 10:19 am
Thanks John!
da gino
Postby HB on Thu Mar 08, 2012 10:26 am
da gino wrote:On a K10 PB/WBC, what should the outer diameter for an alternate hopper be where it inserts in the throat if one were to look for an option other than the mini one that some have had crack?
For what it's worth, I've had three K10 grinders (one for evaluation, two purchased a year+ later). The hopper on the first one cracked as I noted in Solution to cracking Compak K10 mini hopper? The other two have the mini hoppers and (so far?) show no signs of cracking.
Previous
Return to Buying Advice
