Thank you
jammin wrote:For home use, the E model is a poor choice IMO.
mitch236 wrote:Correct me if I'm wrong, but isn't the grind path the same on both models?
JonR10 wrote:I agree, doser Robur is better (for the home?) than Electronic. The E model will require a purge of 20g to 30g before each session....so if you start up and go to pull 2 doubles you will waste 30% of your coffee.
