by da gino on Wed Sep 28, 2011 10:23 pm
They both should be great, they both should outlast you. Not everyone prefers conical to flat burrs even among the experts, but conical is probably a little more forgiving if you dial it in a little off.
I've gotten to play with lots of the titans and I still don't know which one I would take if you let me pick any one that I would get for free and have to use forever (the Robur probably would not be my choice, for example).
I have not even convinced myself that i would rather have flat or conical.
Then again if you told me I was stuck with any of the Titans I've used for the rest of my life - flat or conical - and I did not get to pick which one, I would probably be okay with that because they can all produce great espresso and almost all are built to grind more in a month than most of us will grind in our lifetimes so this would hardly be considered a hardship or sacrifice.
Although I have not used the MXDL (it is as you say, too new for most to have used it) if it is like the other Macaps I've used and other titans from other manufacturers, I don't think you would be shortchanging yourself, but if you are the type (like most of us) to always ask what if, it may not matter which one you would have liked better, but more which one you perceive as better and so there is value in picking that one.
