I seem to have narrowed it down to two grinders: Macap M4 Doser or the Baratza Vario. I see the upsides of both buy I really do not want to purchase another grinder.
Looking for advice on which way to go.
Thanks,
Tom
alex e wrote:I'm selling my Baratza currently. Note that I use it for espresso solely.
alex e wrote:Unless the Vario is outrageously better than the rest of their lineup
alex e wrote:If you aren't into thoughtfulness of design, materials and construction, I bet the Vario is fine.
HB wrote:easily switches between espresso/presspot, etc.)
JohnB. wrote:I wouldn't consider this "easily switching" but it is capable of producing good results at each setting if you want to spend the time.
HB wrote: I haven't found it necesary to recalibrate the burr settings each time, but that may be because I follow Sweet Maria's Brewing Instructions for French Press, which advocates a finer grind.
akallio wrote:And after a couple of sentences you say that it has bad design, materials and construction...
alex e wrote:$500 gets you a lot of upgraded grinder before purchasing that ridiculous Vario.
