aspenedelen wrote:Can someone give me the pros and cons of a superautomatic? What type of price range I should be looking at and if craigslist, buying direct, not buying one and just sucking it up and keep brewing my own 100% Kona and Jamaican Blue Mountain coffee in my $100.00 coffee maker is my best option?
Most people on this site enjoy the tactile nature of making coffee too much to use super-autos so you're going to get bias against these in general. When I started in this hobby/obsession I thought that one touch was what I wanted but quickly found that controlling all the conditions really improved what was in the cup alot. The biggest problem with superautos I've heard is that there are too many parts that can break...in fact I know a guy who swears by them and was trying to talk me into getting one. The way he does it is that he actually owns TWO of them since he often has one in the repair shop...this way he can always have 1 functional machine (some starbucks brand...or actually might have been a Jura).
I recommend reading:
http://www.coffeegeek.com/guides/howtob...ssomachineNow if improving you coffee is what you want, I can provide some much cheaper and more satisfying advice that is fairly simple...
- Try beans from an artisan roaster such as Counter Culture, Intelligentsia, or Ritual to start. Try coffee within 4-10 days of being roasted....it will probably blow your mind relative to "100% Kona" which has probably been sitting on a shelf....this is despite the method of brewing. Most of these roasters ship priority right after roasting so will get to you ready to go
- Upgrade your grinder (or definitely get one) - there is also a big difference between the blade grinders and a burr grinder. Points 1 and 2 are really the basic fact that there is a big garbage in/garbage out factor in all coffee
- Give an Aeropress a try. It is advertised as an espresso maker but it isn't...just makes a damn good cup of coffee if you hit it right that will blow the doors off of any drip coffeemaker. $25, a hot water source, and a few minutes and you are golden.
