Looking for small-ish grinder
I've got a Rocket Giotto V3 on the way, and I'm looking to upgrade my grinder from my current Gaggia MDF. I'd like something that's at least somewhat small - nothing in the Super Jolly territory. A sleek/modern look would be ideal. I will primarily be using this for espresso, but it will also need to be able to grind for French press and Aeropress.
Any suggestions are welcomed!
- dpiette
Small, attractive, unreliable:
My Beloved Pro-M!
I think they stopped making them because of quality control issues. I still have mine, and it works (mostly) OK!
I use it exclusively for espresso, but it is easy to change the grind. The quality of the grind is good.
My Beloved Pro-M!
you can't win,
you can't break even,
you have to play.
-the three laws of thermodynamics
you have to play.
- sweaner
Baratza Vario or Forte would probably fit the bill.
Scott
LMWDP #248
LMWDP #248
Vario or Forte will be your best bet. I'll also be the first to say that you shouldn't plan on using the grinder for espresso AND press/filter. You're much better off getting separate grinders. It will save you a ton of hassle in the long run.
There have been many people including myself who wasted a lot of beans and experienced a lot of frustration when switching. Once you get your Vario set for espresso - LEAVE IT. Make minor adjustments, and you will be a happy customer.
I whole heartedly agreemaxbmello wrote:Once you get your Vario set for espresso - LEAVE IT. Make minor adjustments, and you will be a happy customer.
+2
The moment you leave the macro and come back, you're on a completely different setting ha. For French press get a Lido 2 or a Virtuoso.
