hbuchtel wrote:On manual levers, like my Pavoni, one has to be more careful about waiting to avoid the dreaded 'pf sneeze', especially on tight shots!
This technique works on the Lusso, Microcasa, and Cremina; I don't have a Pavoni to confirm. However, I don't see how it could
not work, since the piston travel before reaching the boiler inlet port has to introduce air through the puck.
Back to the OP, it's worth noting that lever espresso machines with the group bolted directly to the boiler present another challenge that single boiler pump-driven espresso machines do not: The grouphead overheats if the machine is left idle too long. The diagram below shows why:
Hydraulics diagram of Olympia CreminaThe steam boiler provides the brew water and depends on the grouphead to act as a heatsink, cooling the incoming water from superheated +250°F temperatures to brew temperatures. When left idle, the grouphead eventually heats up to the point where it can no longer function as a heatsink. The Lusso avoids this problem by decoupling the grouphead from the boiler and using a thermosyphon to warm it. That is, the Lusso grouphead idles below brew temperature; lever espresso machines like the Olympia Cremina, Elektra Microcasa a Leva, and La Pavoni will idle above brew temperature. The barista can employ certain "tricks" like applying a cold towel to the grouphead before pulling the shot or locking in a cold portafilter to draw down the temperature.
Because the barista has to be cognizant of brew temperature management (and in the case of a manual lever, brew pressure management), lever espresso machines are frequently labeled as more difficult to master than their pump-driven counterparts. I believe is some truth to this assertion, though as demonstrated by the Lusso's simplistic use requirements, it's not a universal truth.
