by boar_d_laze on Sun Nov 13, 2011 9:58 pm
Silvias are an idea who time has left, at least the non-PID controlled Silvias. And, if you want to do more than very limited and occasional steaming, even they're obsolete.
If you want to up your game, and can at all afford it, you should consider moving on to a better grinder as well as a better machine. Your ability and willingness to spend are probably the two most important factors in making a good choice for machine (and grinder).
Whether you should buy an electronically controlled double boiler machine or a high quality but old-tech HX, depends more on your personality and brewing style than anything else. What's perfect for me, could drive you crazy -- and vice versa.
What you're looking for is a machine which will help you pull shots which let you look into the mix. In other words, you're trying to get away from coffee which tastes like coffee, you want to make coffee that tastes like the coffee. And of course you want a machine which will do it consistently and hold up over the years.
In the US, the ~$2500 market is dominated by a few very good (but not top of the line), double boiler machines. Yes, there is a difference in the cup between the prosumers and the extreme, true professional, high end DBs like the La Marzoccos and Synessos; and a large difference in construction and component quality. I'm not sure why they're more revealing and more rewarding to good technique, but suspect that most of the difference is in the group.
Think about the Alex Duetto, La Spaz, VBM DD and latest Brewtus iteration. They're all well made, and capable of a lot of consistency. None of them are machines you have to do much to work around. Everything else being equal, I doubt you'll get much difference in the cup, so think about what fits your home better, and what you can buy and have serviced without too much trouble.
Understand, the difference between a $2500 prosumer DB and one of the ultra high-enders are not large. Without a great grinder, a great mix, and solid barista skills you wouldn't notice. Good espresso machines not only won't fix problems with the rest of the chain, they make them more obvious. The better the machine, the more capability it has to illuminate nuance. That's a double edged sword.
I'm not an expert by any means, so take it as an FWIW. I prefer better HX machines over DBs. It's partly price. I've experienced and been told by my betters that you can get every bit of consistency and revelation of nuance with a $3000 HX (such as mine, which is probably not available in the UK) as with even the most expensive DBs; but doing it consistently takes more time and attention. An ultra high end DB is surely a better choice for an espresso bar, but if you enjoy putting the concentration and extra steps into pulling a shot, than an HX might be perfect for you. Plus, at more realistic price levels, you get more quality-bang for the buck with an HX.
FYI, an E-61 is a good group; not just for HXs, but for DBs as well. But there are other groups just as good, and a few even better. They mostly start happening above your stated price range, though.
Whether you choose a DB or an HX, plumb in if possible. The convenience of "wasting" water and not running to empty the drip tray will allow you to improve your skills no end. Not to mention the "aroma."
At the risk of nagging, a Rocky isn't the right grinder for a $2500 espresso machine. Not by a long shot.
Good luck,
BDL
