hugz wrote:There's no way I could justify the expense of a new FB (like $6000 more than the Linea), but reconditioned the price difference would probably just be like $1000 which might cover most of the cost of the mods anyway.
If you are looking at a 3 group Linea, with Piero Caps and PID'd brew boiler you are looking at probably closer to $1600 worth of modifications (parts only). Piero Cap kit is usually around $400, or more depending on the version of Linea you have, and you would need 3 of those. You can buy the kit for the PID, or parts bin it, but your still going to spend at least $200 on the parts. Then if your not handy it will cost you for install.
I just rebuilt a 1998 Linea 2AV, the PID is actually really easy to install, just need to source some good wire, and find a place to mount the controller and the SSR. That being said, if you do not already have the machine stripped to the frame, installing the thermocouple, might be a nightmare due to it's angle, and the fact that needs clearance to get in place. As for the Piero caps, I'm going to say on a scale of 1-10 (1 being easy, 10 being difficult) they are somewhere in the range of 6.
I personally love the straight sided, "industrial" look of the Linea, and instantly notice it in any cafe. That being said, the FB80 is the opposite, with very sexy curves. If your into customizing the machine to match your Cafe, the FB80 would be a better choice, as it's skin is obviously easy to paint, and customize, where as the Linea, has enough panels, trim and screws to make a grown man cry when he has to remove the inner most layer to find out what is leaking.
