La cimbali m21 or La Spaziale S1 rossini
Postby sbh61 on Thu Mar 26, 2009 3:40 am
Hi,
I have an offer to buy one of these machines:
The la cimbali is brand knew and the La Spaziale S1 has been used for demonstaration.
The La Spaziale is priced 300$ higher,
I would appreciate some advise.
Shai
sbh61
Postby jorgen83 on Thu Mar 26, 2009 5:36 am
Both pretty high-end machines, with a couple of differences: La Cimbali is a Heat exchanger, La Spaziale is a dual boiler machine. The Cimbali is made like a tank, all-metal and virtually indestructible, whereas the La Spaziale has a lot of plastic parts. I can't really give you more than that the dual boiler La Spaziale (with optional preinfusion?) is more easy to use than the Cimbali.
jorgen83
Postby timo888 on Thu Mar 26, 2009 8:09 am
Indestructability would not be really high on my list of priorities for a domestic espresso machine. But whether the machine was a heat-exchanger or a dual-boiler would be at the top of the list. With heat exchanger designs that superheat the brew water, you need to control the brew temperature by flushing the right amount of water and then waiting the right length of time before pulling the shot. Err, and with some machines err just a little, and you produce a bitter swill. Double-boiler machines like the La Spaziale do not superheat the water and are therefore easier to use and much more forgiving. Double-boilers like the La Spaz also take far less time to heat up and do not need to be kept on all the time or turned on an hour before you want to use them.
timo888
Postby JohnB. on Thu Mar 26, 2009 10:28 am
The Rossini is not the same as the S1 Vivaldi we get here in the U.S. It is NOT a dual boiler machine as it uses the .45 liter group boiler for all functions (brew/steam/hot water).
LMWDP 267
JohnB.
Postby zin1953 on Thu Mar 26, 2009 1:40 pm
Direct from La Spaziale:
S1 ROSSINI:
  • One group coffee machine
  • Free flow delivery in the semi-automatic
  • Electric heating
  • Electronic temperature regulation for coffee delivery group
  • Built-in safety thermostat
  • Indicator to warn of low water level in the tank
  • Temperature indicated by LED display
  • Automatic cycle for steam delivery
  • Semi-automatic hot water delivery for infusions
  • Built-in vibrating pump
  • 0.45 liter boiler for coffee delivery
  • 1 hot water outlet and 1 steam wand
  • Fault Diagnosis Alarms
  • Power supply and absorption of the machine: 230/110 V - 50/60 Hz - 1250 W
  • Available in two versions: Internal 3 liter tank, or Direct connection to the water mains
S1 VIVALDI:
  • Electronic one group coffee machine
  • Proportioned dose setting
  • Electric heating
  • Electronic temperature regulation of the boiler for hot water and steam delivery
  • Electronic boiler refill
  • Built-in volumetric pump
  • Direct connection to water mains
  • 2.5 liter boiler for hot water and steam delivery
  • Power supply: 230/110 V - 50/60 Hz
  • Power Absorption: 1250 W boiler heating element 800 W group heating element
  • Possibility of excluding the boiler heating function
  • Economy function (maximum absorption 1250 W)
(Note: I do believe that the ROSSINI model is not sold in the US; also, the MINI-VIVALDI is a pourover model.)
Personally, I'd grab the Cimbali . . .
zin1953
Postby jorgen83 on Fri Mar 27, 2009 7:07 am
Aha, then I'd get the Cimbali as well.
Kinda stupid to name such different machines similarly...
jorgen83
Postby JohnB. on Fri Mar 27, 2009 9:47 am
jorgen83 wrote:Aha, then I'd get the Cimbali as well.
One is called the Vivaldi & the other the Rossini. Not all that similar. They are both in the S1 family & share various pieces including the body shell.
LMWDP 267
JohnB.
Postby jorgen83 on Fri Mar 27, 2009 12:41 pm
I know, that's why I said similarly and not the same. Still, I would shorten both names to LaSpaziale S1, and seeing they're really different, that's bad.
jorgen83
Postby zin1953 on Fri Mar 27, 2009 1:06 pm
Again . . . Vivaldi and Rossini are VERY different -- not only in the music they composed, but in the machines that carry their names:
S1 = family name (think Mercedes Benz).
Rossini = single boiler, available as plumbed-in or pourover (think C class, available as a sedan or a convertable).
Vivaldi = dual-boiler, available as plumbed-in or pourover* (think E class, available as a sedan or a convertable).
Cheers,
Jason
* To me, the only weird part re: the names is that the pourover Vivaldi is known as the "Mini Vivaldi." Why isn't the pourover model of the Rossini called the "Mini Rossini"???
zin1953
Postby Jabbawack on Sun Aug 29, 2010 6:30 am
If I understand correctly, the Rossini in a single boiler, not an HX? But i've never seen a single boiler with the hot water tap (althought I don't have much experience).
I've found a Rossini for 400€, 2 years old, but it's a bit big for me.
Jabbawack
Next
Return to Buying Advice
