Real Name: Dirt
Yes, well, welcome "dirt" to home-barista . . . being from the planet Earth is helpful, because most machines on this planet require the use of two hands equipped with opposable thumbs . . . I shall presume, from your command of the English language, that you are in the US or Canada, and that you will -- in all probability -- be getting your machine from Chris' Coffee. Great vendor; great support before AND after the sale . . .
Be that as it may, I'm curious as to why you picked these two machines. What was it about them that caught your attention?
By the way, although there is only one model (to my knowledge) of the
Izzo Alex Duetto II ($2295), there are two different models of the Cimbali . . . which are you thinking of, the
La Cimbali Junior DT1 ($3595), or the
La Cimbali Junior S1 ($3095)?
All three are fine machines, but what
my choices would be may be different than your choices. So, with that in mind,
were it for ME, I'd get the Cimbali Junior DT1, the Izzo Alex Duetto II, and Cimbali Junior S1, in that order. For YOU, however, I suspect the order would be the Izzo Alex Duetto II, followed by the Cimbali Junior DT1, and then the Cimbali Junior S1, in
that other.
The "pros" of the
Cimbali DT1 are its excellent workmanship; it's built like a tank! It is a rock-solid, time-tested, proven design with a good customer base. It features volumetric dosing, which I find to be a significant plus. It has a rotary pump. (The Cimbali Junior S1 has a vibe pump.) On the downside, it's more expensive than the Izzo, and
must be plumbed into the water supply (though you indicated this wouldn't be a problem).
As for the
Izzo Alex Duetto II, although it is relatively new to the US market, it has an ever increasing customer base. It is a double-boiler machine, which may be an advantage
in terms of your expressed concern for "ease of operation." (Either machine will deliver
in the cup, where it counts.) It also has a rotary pump, is readily switchable from pourover to plumbed and back again, and is substantially less expensive than the DT1. The downside is that, because it is so new, no one has used it over the course of 5 years, 10 years, 15+ years (as have Cimbali owners).
A few final thoughts . . .
a) If you haven't already, I would strongly encourage you to read the
"Buyer's Guide to La Cimbali Junior DT1" by Dan Kehn. Also search this site for posts on the Cimbali Junior DT1 by Ken Fox.
b) The Cimbali is a Heat Exchanger (HX) machine, while the Izzo is a double boiler (DB) model. There is nothing inherent in the design of either machine that makes one "better" than the other in terms of quality in the cup. "Temperature surfing" seems to put some people off, but I've found it quite easy to do, and it's quite easy to reproduce quality shots. The most difficult thing about "temp surfing" is to explain it. It takes longer and is more complicated to explain than it is to do. (Again, if you don't mind the sufestion, I would also urge you to read
How I Stopped Worrying, and Learned to Love HXs by Dan Kehn.)
That said, for "ease of operation" with limited experience, you may find the DB design more to your liking.
c) With the money you save on the Izzo, you can get a better grinder.
Cheers,
Jason
