by peacecup on Wed Dec 22, 2010 4:58 am
Hand grinding definitely takes a little more time. The old box mills can grind 15g in less than a minute, probably more like 30 seconds, without rushing (not sure how long the Kyocera takes). On top of this time, however, one needs to add the time of getting the coffee from the drawer to the portafilter, probably another minute all together. So it takes 2-3 minutes to grind and dose.
The Vario probably takes 30 seconds or less to grind and dose. On the few occasions when I am in a hurry, this time factor seems very attractive. If I were ever to find myself with the space, means, and could accept the noise factor, I would take Hal's advice and go for the Vario.
Hand grinding is a bit of a Zen experience, and one must accept the time factor. If limitations in noise level, space, and price are issues, hand grinding can be a very attractive alternative.
PC
LMWDP #049
