avdiscolo wrote:The only thing holding me from going with the Compak K10 Pro Barista is the size. Our cabinets are a tad over 17.5" high and even with the short hopper the K10 is 19". In addition, the specs say the K10 is 14.5" deep (really?) and if it can't fit under the cabinets, I don't see how it will fit on the counter.
I've read that the throat of the K10 is pretty large, so running the grinder without a hopper may be a possibility. How much coffee can fit comfortably in the throat? Does anyone have any experience running a K10 in this manner?
Yes. I think it's the best way to use the grinder, but I'm a fan of single dosing.
I upgraded from a BV to a K10 WBC (still have the BV and use it for vac-pot and press.) My cabinets are a tad under 18" high and 12" deep. The countertop is a tad over 26" out from the wall, including the backsplash. That leaves about 14" of unobstructed countertop in front of the cabinets.
As you surmised, the K10 can't fit under the cabinets with the short hopper. It does fit under the cabinets without a hopper, so in theory you could single dose. But with a height of about 16", there's not enough room to get your hand under the cabinets with a scoop or cup full of beans, and no room for a tamper or spice bottle to prevent popcorning. Not practical.
What to do? With 14" of counterspace in front of the cabinets, there was enough room to park the K10 with the entire grinder out from under the cabinets. The suction feet are set back from the leading edge of the grinder base by about an inch. As long as the front feet are on the counter, the portion of the base in front of them can hang over the edge.
But I wasn't about to waste that much valuable counter space on a permanent basis. It happens to be right next to the range, in the prime location for temporarily placing pots, spoons, food, etc. needed when cooking. Besides, the grinder would have looked silly sitting that far out from the wall, with part of the base hanging over the edge of the counter.
I solved this problem by storing the grinder under the cabinets when not in use, and pulling it out from under the cabinets when I need to use it. The grinder's powerful suction feet would make this too difficult to do on a regular basis, so I made a pad for the grinder out of black foam board cut to the exact outline of the base. The foam board allows the grinder to slide easily on the Corian counter, but the weight of the grinder keeps it from moving around when the motor is running. The grinder is perfectly stable when operating. Thus, I can easily slide the grinder forward when I need to use it, then back out of the way when I'm done.
When I first came up with this, I remember Jim Schulman telling me to pull the foam board, not the grinder. He probably thought I would pull the grinder by the doser or some other delicate part. I started out by putting my hand behind the grinder, sort of half-hugging it, and pushing it forward. But eventually I ended up just grabbing the forks, putting a hand on the back, and pulling. The forks mount is plenty rugged. Besides, the foam board doesn't provided a lot of resistance.
Note that you don't need a full 14.5" of counter in front of the cabinets for this to work. To single dose, the grinder throat needs to be clear of the cabinets. But the back of the throat is not at the back of the grinder. There are several inches of grinder between the back of the throat and the back of the grinder. In fact, you only need about 10.5" in front of the cabinets to get the throat clear. That's the distance from the back of the throat to the front edges of the front suction feet. As noted earlier, the portion of the base in front of the feet can hang over the edge of the counter if necessary.
The throat is plenty large enough for the biggest dose you would every want to use, with plenty of room for a Spice Islands spice jar to suppress popcorning. Mine contains peppercorns and is still sealed. Should I need the peppercorns I'll replace them with nuts and bolts. (You know, it's a real tribute to Jim Schulman that many of us use the same brand spice jar he uses
If I need to make drinks for a crowd, the small hopper can be mounted by pulling the grinder out a little more. The short hopper only requires an extra couple of inches of counter space -- about 12 1/2" in front of the leading edge of the cabinets. I haven't tested the large hopper (it's in a box in the basement), but I think it would fit with the grinder pulled out as far as the countertop will allow -- probably with the base hanging out over the edge, but the feet securely on the counter.
