jorgen83 wrote:I had already thought about getting two machines to make for a makeshift two boiler setup, but that's not going to fly with my girlfriend.
You have to make her understand that you do not _need_ the HW, but just have a discerning taste. That's why you chose her and need extremely delicious espressi. The kit is secondary.
By the end of a serious meal in a serious restaurant (National Top 20, Michelin stars), my wife would say she would like an espresso and then we decide to have it at home, because it is plain better.
Take your SO to e.g. De Koffie Salon (Utrechtsestraat, Amsterdam) or Palladium (around corner of Leidseplein, Amsterdam) and have espresso. Both have Kees van der Westen machines, the former lever, the latter E/61 based, and excellent Italian coffee (Roman style).
As to space, in a student's condo you may have little. My house has a small kitchen and I decided to put the espresso stuff in my music room. A trolley from Ikea (stainless steel) with a drawer to hold the knock box and accessories/tools, a lower open shelf to hold the bulk of demitasse cups/saucers, some spirited drink, and on top the HX machine, grinder, scales, tampers and a jar with coffee beans.
jorgen83 wrote:If I pick it up myself like you did, does that also mean there's no shipping costs?
Before deciding to go there, make sure this is still an option for your preferred machine. Next settle administratively with e.g. Chris and do not arrive unannounced at the factory in their holiday period.
They did not charge me any shipping - it really was the place where they put everything together. Make sure you have a good GPS system, though.
jorgen83 wrote:Otherwise buying secondhand is no problem at all, but what should I pay extra attention to with older machines?
If you are capable of some DIY plumbing, you should be able to do many things yourself. You need not be capable of the ultimate zen of motor maintenance. Wear of parts depends on use. If a machine is on a time or manually switched on/off frequently it heats/cools more often and the respective expansion/shrinking will cause more strain on joints, seals and parts. On my machine the first part needing replacement was the vacuum valve on the boiler. Safety valves probably last a lifetime. Other parts that might need replacement are the water pressure regulator, pressurestat, etc. A search on the internet will learn you these parts are not extremely expensive (unless you want a Sirai pstat and your machine has space enough to host it).
Probably a bit more expensive is the boiler water level sensor with electronics box.
Question is why somebody does away with a good machine? Because it was not looked after well (no frequent maintenance, no descaling, etc.) and the machine looks really aged, then I would expect to have to replace most vital regulation parts and potentially boiler, copper tubing and group.
A big worry may be, especially if you want to safely adjust parameters with the machine running (230V) is the electrical insulation on connectors may have become brittle because of prolonged heating and not be safe anymore. In which case you have to rebuild/replace the wiring loom.
I hope this gives you enough negotiation points for buying 2nd hand.
Take care.
Peter
Netherlands
Europe
