by p.a.giasson on Tue Dec 20, 2011 12:39 am
Hey there!
Over the past few years, I dropped my basic Breville espresso machine to switch to a Cuisinart brewer. The Breville is already pretty basic and makes coffee which I consider to be "ok". Why did I switch? In the morning, I like to leave home with a big mug of coffee. Filling the mug with espresso is just too long since it takes two or three shots to "brew and go". Also, when I wake up, I'm just too sleepy and lazy to start the machine. The only way for me to make my own coffee at home before leaving for the office was then to get a coffee maker with a timer. How's the coffee? Not that good... Do I use the machine more often? Of course!
With that said, I would like to go for an espresso machine which will be easy to use even if I still got the eyes closed and which will be quick to use when I come to leave for the office. I've read a post about Nespresso, but I'm afraid that it'll get expensive with time. If you drink two coffees a day at 75 cents each, it means that you've spent about $550 at the end of the year. After three years, that already makes $1,500 without even counting the machine itself. Also, if I want to fill a regular 12oz mug, how many pods or cups will I need?... It's not that I can't afford this kind of money, it's just that I look at that and I feel like I'm paying more plastic than coffee.
So here's the problem: I've heard about automatic machines. I don't know the difference between a semi-auto and a full-auto... Well, actually, I know the difference, but not for espresso machines. Is there any machine which will be suited for me? Does an auto machine such as a the Saeco Xelsis or the Saeco Syntia will give a "decent" coffee? Of course, if I could get a cappuccino, it would be even better!
There one more thing which I don't like with the Nespresso and the Keurig systems: there's a lot of waste for the quantity of coffee made. Also, those can't go to compost, whereas the coffee grounds can...
As for my budget, there's no real fixed limit. Of course, I'm not wealthy enough to hire a waiter who will serve my coffee every morning. On the other hand, paying $!,000, $1,500 or $2,000 is not really a problem. As I said, I don't like the idea of paying for plastic cups. However, "investing" on a good machine is an option to consider.
What's your thought on that?
Thanks!
Pierre-Alexandre
