HX vs double boiler in the real world... - Page 2
Postby HB on Thu Jul 24, 2008 2:25 pm
JohnB. wrote:I can reduce or increase the temp on my Vivaldi, do a 2-3 oz flush & have full recovery in less then a minute.
True, but that only means the boiler is at the new setpoint. The grouphead, portafilter, and other metal bits need time to stabilize too. Depending on the espresso machine, you can shorten the transition time by flushing (e.g., flush... wait a couple minutes... flush... wait a couple minutes... short flush and pull).
Postby JohnB. on Thu Jul 24, 2008 2:44 pm
Even after a long idle period it only takes 2 short (2-3oz) warming flushes to bring the Vivaldi grouphead & p/f up to temp with a 50 sec waiting period between flushes for boiler recovery. That would be the most that was required after a temp change of a few degrees C. Thats a long, long way from the 1/2hr mentioned previously.
LMWDP 267
JohnB.
Postby HB on Thu Jul 24, 2008 2:53 pm
Dave was probably thinking of large double boiler espresso machines like the La Marzocco, and to a lesser extent, the Expobar Brewtus. My point was that just because the Vivaldi's readout stops blinking after a change, doesn't mean that it's ready; as you noted, additional steps are required.
Postby cannonfodder on Thu Jul 24, 2008 4:11 pm
The larger machines like a single group LM take a while, the big multi group boxes take even longer. On something like Vivaldi I would give it 15-30 to stabilize. You can flush the group but you still have 50 pounds of copper and steel that needs to reach equilibrium. That takes a little time. As Dan stated you can speed the process with a bunch of flushes but I prefer to let it level out on its own, unless it is a big old 4 group that will take an hour or two.
cannonfodder
Postby JohnB. on Thu Jul 24, 2008 5:28 pm
You're changing the brew boiler/group head/porta filter temp a degree or two C on a machine that is already up to temp. The steam boiler may not even be on & you are going to wait for a frame rail in the back to notice the slight change before pulling a shot?
LMWDP 267
JohnB.
Previous
Return to Buying Advice
