mlc85 wrote:Sometimes I need to make 6+ drinks at the same time. I was wondering how much faster a DB machine is when making that many cappas for people compared to an HX. Specifically is the quickmill Anita good enough, or is the $800 worth it for a La Spaziale Vivaldi II?
The prosumer / semi-commercial sweet spot for steaming is around 8 ounces. If you're into big gulp lattes, Anita will not keep up. If you're into modestly proportioned cappuccinos and prepare them serially, Anita and her ilk will do fine. That said, the advantage of the big steam machines isn't just capacity, they frequently have an advantage of producing velvety microfoam more easily. For example, the Elektra A3 is a steam locomotive
and the only reviewed espresso machine to earn an unqualified perfect 10 for its "cappuccino lover's" score.
ira wrote:One of the users on the Brewtus list did a test with various tips and with the stock 1 hole tip he could essentially steam continuously.
But you will need the patience of Job to steam more than 8 ounces with that tip. It is glacially slow, albeit very easy for newbies.
