I wish I had the cash to purchase one of each and run them through the testing cycle...
The way I test grinders is setting the grind on each grinder in the sample, using the same roast to extract as similar an espresso as possible. This helps insure I've got all the grinders in the sample group as close to the same grind as possible.
Then I grind a 10 gram sample for each and sort and weigh the particulate into ranges with micron screens. Then compile the data and produce the report.
What I've found with the few grinders I've done this with are that the Mahlkönig ceramic burrs have performed with the smallest range in a sample and higher weights in orientation to the statistical mode.
This is how I view the quality of a grinder. I'd love to have others weigh in as I'm not a stats expert, but this model makes the most logical sense to me.
I do stay away from dosers, I just don't like the whole additional exposure to air and the tendency for baristas to grind away and not purge. Even if you do purge, there's always remaining grounds ready to contaminate the next dose.
In my shop, I use a Mythos and love it for daily abuse, day in and day out. It doesn't have Mahlkönig burrs, but does have a nice 83mm angled flat burr. It's performance based on how I test is comparable to the Mahlkönig burrs, just not as accurate.
Paul
...split from Choosing a grinder from an extensive list; Which one? by moderator...
