Where is that video?
mitch236 wrote:I won't be using the auto-dosing function because there really is no need for it in my routine. I like the doser-less funnel and not having to thwack-thwack the doser which is why I converted my Mini to doserless. So for now, it seems I will just use the manual button. This grinder is so fast that I can't see how there isn't more waste in the doser version due to over-grinding. It only takes about 3.5 seconds to pile up my LM ridged basket.
Bob_McBob wrote:I don't get it. You bought one of the most expensive espresso grinders ever made, and you're not going to use the 0.1s timed dosing feature that gets you consistent doses every shot? Instead you're going to dose by eye at almost 5g/s without the ability to hold excess in the doser, knowing 0.5g makes a difference?
mitch236 wrote:As it turns out, I was wrong. The doser is so accurate that I did end up adopting it. I was intimidated by by setting it and all the waste but it turns out, it is very easy to set and now I get extremely consistent dosing!
wildbwilson wrote:My waste factor has dropped considerably though I still pulse through 5-10 grams out of respect for the fresh coffee coming through.
