High Quality Single Boiler Machine Only for Espresso
My experience with single boiler machines is that they are a compromise between two disparate functions, and are mostly designed with too little thermal mass in the head, and too small a boiler without good regulation. The single boiler heat transfer machines are wonderful to think about, but that technique is still a compromise. Is there a machine with a high thermal mass head, a large well regulated boiler, and no frills and compromises, that is, no frothy milk capability?
- another_jim
Jim Schulman
- HB
- Admin
The Quickmill Alexia with optional PID and The Arrarex Caravel also come to mind.
- [creative nickname]
Or if you are handy, you could just build your own, like this guy did:
Anyone seen this diy espresso machine [video]
LMWDP #435
- blueface
Thanks for all the responses! The LM is a bit large and expensive. If it were the only thing out there I might find a way, or build my own. I have thought about that, but my projects tend to me more electronic than mechanical, and I really do not have the time now. The Classika II is very beautiful, but with the less expensive Alexia available, that is what I am thinking about most.
- Carneiro
There is the Bezzera Unica, already with PID, and the Bezzera BZ09 (not in the US...) for a different kind of group (as Jim say, it should be similar to Elektra Semiauto shots, and I can tell they are great).
+1 on the Alexia.HB wrote:The Quickmill Alexia with optional PID and The Arrarex Caravel also come to mind.
+2 on the Alexia. With PID it's Awesome!HB wrote:The Quickmill Alexia with optional PID and The Arrarex Caravel also come to mind.
Jim
"There is the Bezzera Unica, already with PID, .........."
I decided to go with the Unica when shopping for the same thing. Less expensive than the Alexia, and I thought the Bezzera line has great fit and finish. The Alexia's boiler is larger though, .75 L to the Unica's .5 L
The Unica also comes from the factory with a Lever on/off steam control, that I find quicker and easier to use than the standard twist on/off valve.
