by another_jim on Sat Jan 22, 2011 3:17 pm
The machines are virtually identical in taste, and the wand on the 02 will work fine on any normal sized jug.
The 07 is prettier and more compact, the 02 is roomier inside, therefore easier to maintain.
The models I tested had different fothing tips. The tip on the 02 was a very slow frothing single or two hole "amateur" tip, whereas the one on the 07 was a commercial 4 hole tip that ran beautifully. I do not know which of these was stock, or how to make sure you get the one you want. Give your vendor a call on this when you buy.
