chang00 wrote:The grind from the Mini is suitable for my Anita and Factory. For about 12g for the Factory, it requires about 200 turns.
Both hand grinders have extensive plastic. I have used the Mini and Skerton about once per week for past year.
Hi, Henry and everyone.
How do you compare the grind quality of both grinders at the range for espresso? I got a Hario Slim, and I'm having a hard time to use it with my Classic (just testing). The OPV is set at 9 bar, and when I dial the Slim so I can get some flow, the grinder is not so consistent, and I got a bad extraction. It seems that when I go finer I have a better grind, but than the machine chokes.
When I look the inner burr movement, I see it is not so centered as I think it should be... I wonder if the Skerton or Kyocera is better...
Thanks!
Márcio.
