by SlowRain on Tue Dec 21, 2010 11:53 am
I have a Sözen Turkish mill, a Hario Skerton, a Kyocera CM-45, and a Porlex (the taller, old style one). I use the Porlex for espresso as it has the best burr stability. I find the Kyocera burrs too loose--both the clip that holds the inner burr to the shaft and the pegs which hold the outer burr to the frame. The Kyocera, however, is fine for AeroPress, but it does have a static issue. The Sözen is great for Turkish coffee (obviously!) and about as good as the Kyocera for espresso, but not so good for AeroPress. The Hario Skerton is almost useless to me. I don't use it. I personally feel this grinder is trading on the Hario name and not on the grind quality it produces. However, it is cheaper, which must be taken into account.
Now having said all that, Orphan Espresso's remodeled Kyocera CM-50 looks very good. Essentially, it's a Hario Skerton, but they've solved the burr-wobble problem. Take note: Kyocera hasn't solved the burr-wobble problem, Orphan Espresso has. As much as I dislike the Hario Skerton, what OE has done to the Kyocera CM-50 makes it a very worthwhile consideration. I'm very interested to know if anyone has purchased one and what they think of it.
So, my recommendation to you would be either a Porlex or the remodeled Kyocera CM-50 from OE.
