ramatevish wrote:I'm thinking about opening it up tomorrow to give everything in there a once over and give it general maintenance.
Definitely a good idea. You may want to soak the shower screen, dispersion block, baskets, and portafilter (just the metal part) in JoeGlo, Urinex Cafiza, or another espresso machine detergent.
ramatevish wrote:<image>
The setup - everything but the grinder and the little bean bag was included in the $125 price.
I don't think you could ask for a better start!
ramatevish wrote:I'm going to try steaming milk tomorrow with it (the steam pressure and temp seems to be fantastic) but I'm not sure about the "steam enhancer" nonsense on the end. Any ideas on how to remove it?
Yes - pull the longer plastic sleeve off of the top, shorter plastic piece. Then unscrew the top small plastic cap to separate it from the nozzle (which is hidden by the outer plastic sleeve). I replaced my Gaggia steam wand with a Rancilio Silvia (V2) wand, which gave a bit more steam power, but this should work well. When steaming, be sure that the machine is at shot temperature (ready light has been on), then press the steam switch, wait 30 seconds, and start steaming. You want to start before the steam ready light comes on so that the heating element remains on and plays catch up with you, giving you more steam power.
ramatevish wrote:(they had a smaller one with a PID for cupping at another counter)
When I was there, there was a La Marzocco GS3 and Versalab M3 grinder at their single origin bar, where they offered any of their coffees as drip or espresso.
ramatevish wrote:Also, my god were there hipsters, just everywhere! I thought it was bad in Berkeley but SF is beyond compare.
Surprised?
ramatevish wrote:Also an (slight) issue is the boiler size, which is small. I'm pretty sure I can solve that by preheating the water I put in the reservoir, which should allow for a stable temp through the pull.
Be careful with this - I've read that vibe pumps can be damaged at higher temperatures. I wouldn't recommend preheating unless you can add a preheater in the machine between the pump and the boiler. I got better temperature stability by starting with a hot (ready) machine, then flushing until the ready light went out, then waiting for the light to turn on, then pulling a shot. If you need the temperature higher, you can turn the steam switch on for 1-5 seconds after the ready light comes on, turn it off, and pull the shot.
Good luck!
