Grinder Advice - Compak E5 vs Fiorenzato F4 vs Eureka Atom - Page 5
Hi there
i'm using Sette 270 which is dead yesterday morning for no reason. So i was looking for other options and discovered Atom. I'm between Eureka atom and Ceado 37J .
I single dose, i don't like to keep my beans in the hopper. The sound is a plus but after Sette everything is quiet so no problem.
Could you please post some grinded coffee? What i really like about Sette 270 is the fluffy grinded cofee, just perfect. I really don't care about the speed or the noise but the result. Some of you mentioned about popcorning, i'm also concerned about this.
- jeffb
I had an F4 (my son now has), upgraded to Monolith Conical. The F4 was quiet, fluffy grind, low retention, clean and easy to use and take care of.
I would buy one again and use.
I enjoy the Monolith but for the money, I believe the F4 is outstanding.
Interesting I have not seen any spraying on "my Atom". On par with my former MK ProM...
After reading a few other threads, seems like Eureka Atom is definitely the go-to for its quietness and ease of maintenance.... but not good for single dosing, which i am quite used to due to previous experience of hand-grinding and frequent change of beans.
The struggling point now becomes if I want to get an E5, where can I get it (in a 220v country) and whether there will be new grinders coming after SCA
- redbone
BellaBarista in the U.K. carries the Compak E5.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Yes redbone but they're out of stock except the red one ... and out of person pref I do not like red =(
For Atom owners - any of you know if the burr inner diameter is same as 65E? (which shouldn't be but Im just hoping it might be the case because I found a single dose cup that might work if they are the same =S)
Did you end up trying a single dose cup on the atom? did it work?For Atom owners - any of you know if the burr inner diameter is same as 65E? (which shouldn't be but Im just hoping it might be the case because I found a single dose cup that might work if they are the same =S)
