Getting first set up, convex or flat tamp?
Postby tekufah98 on Mon Oct 19, 2009 8:46 am
Hi, so I've just gotten my first espresso machine, and now am getting all the other necessities, as i'm looking at tamps, i've just realized that they make flat tamps and convex tamps, I read about what the advantage is of having a convex tamp, but am still not sure if I should get a convex or a flat. Could i get some advice?
thanks
tekufah98
Postby zin1953 on Mon Oct 19, 2009 10:15 am
Aaron,
Don't over-think this!
There is nothing to it. Tamping (and tampers) is the most overrated part of the whole bit . . .
Flat? Convex? C-curve? Pretty much boils down to personal preference.
  1. There is some opinion that a convex or C-curve tamper may "seal" the puck better against the sides of the basket, but then some people tap the tamper against the side of the portafilter and so disrupt any "seal" that may exist.
  2. There is some opinion that the shape of the shower screen should (help) determine the shape of the tamper -- a flat screen dictates a flat tamper; a curved screen dictates a curved tamper.
Personally, I subscribe to #1, and I'm not totally sold on #2. For that reason, I have a convex tamper but a flat shower screen.
Also, it's fairly important that the tamper feels comfortable in the hand -- something hard to do online, but nonetheless . . . online is where I have purchased all my tampers. Espresso Parts NW has an extensive selection of tampers, but they are only one source.
Cheers,
Jason
zin1953
Postby tekufah98 on Mon Oct 19, 2009 11:23 am
thanks, yeah right after I posted this I like clicked two links and found a plethora of posts with a pretty easy consensus that convex and c-curve is usually used, so i'll just get that
i'm also having trouble finding what the proper size tamper I should get,
I have a new (millenium) la pavoni Europiccola
is this something else i'm over thinking?
tekufah98
Postby Stuggi on Sat Oct 31, 2009 11:14 pm
Reg Barber makes tampers in any size, even for the Europiccola. He also has a couple more options on the shape of the tamper;
Flat
Euro Curve
US Curve
C-Flat
Ripple
C-Ripple
The Euro is more curved than the US. C means curved sides but flat center. Ripple means concentric rings machined into the flat surface, C-ripple means that with curved sides. The ripples are AFAIK only cosmetic.
Sebastian "Stuggi" Storholm
LMWDP #136
Stuggi
Postby Stuggi on Sat Oct 31, 2009 11:15 pm
Oh, I forgot, the EP Millennium should have a 51mm tamper if I remember correctly. I'll measure mine tomorrow.
LMWDP #136
Stuggi
Postby uscfroadie on Sun Nov 01, 2009 2:11 am
It's a 51.
Merle
LMWDP #273
uscfroadie
Postby michaelbenis on Sun Nov 01, 2009 7:05 am
Yup 51mm.
Question: what is your grinder?
Anything less than a Rancilio Rocky, Mazzer Mini/Super Jolly or Baratza Vario and I'd recommend that you just get the cheapest 51mm tamper you can find and put the money towards the grinder. Nothing will make a bigger difference to your coffee - apart obviously from the quality of your beans.
Cheers
Mike
LMWDP No. 237
michaelbenis
Postby HB on Sun Nov 01, 2009 1:40 pm
Postby tekufah98 on Sun Nov 01, 2009 3:18 pm
michaelbenis wrote:Yup 51mm.
Cheers
Mike
I got myself a Kyocera hand grinder, since I don't have the money for a high end electric grinder, and it's been pretty great sp far for what it is. I also just got my 51mm convex tamp from espressoparts and it doesn't fit, what's wrong? I got the machine brand new in the beginning of October so I'm pretty damn sure it's a post-1999 machine. The tamp just barely goes less then a half a cm into the portafilter and gets stuck.
tekufah98
Return to Buying Advice
