zin1953 wrote: But considering there is a two-stage thermostat on an SBDU -- one set to brew temp; the other for steam temp -- generally speaking, not a lot of temperature surfing was required. Nor is it with any SBDU. (Of course, people can and do temperature surf a Silvia, install PIDs, and so on. Some people are also more fixated than others, but that's neither here nor there.)
The Silvia takes longer to heat up because it has more brass and, thus, is more stable -- less prone to wild swings in temperature. (My current machine is even larger and takes longer than a Silvia, but it is even better adjusted and thermally stable. However, being an HX machine, temperature surfing is essential.)
I disagree with your assessment of a two-stage thermostat, as well as the notion that "not a lot of temperature surfing [sic]is required". My Silvia has separate 2 thermostats, one each for brewing and for steaming. Randy G. also has
wiring diagrams on his website that show how Silvia is wired, which leads me to believe that this wiring method is common for all Silvias. I can't speak authoritatively for any other SBDU. As far as the surfing part, I switched to a PID, and couldn't imagine going back. It was, at the time, a world of difference in terms of consistency. On this point, we may agree to disagree; for my money, surfing a Silvia was required.
One of the struggles with any machine in this class is temperature stability, due to the use of inexpensive button-type thermostats which can have tolerances of ~30F. This means that the thermostat clicks "ON" and engages the heating element when it senses a temperature of 190F, and "OFF" when it senses a temperature of 220F.
When the "Steam" switch is engaged, the brew thermostat is essentially overridden, and the steam thermostat engages, cycling between ~250F and 280F(at least, this is based on measurements taken from my PID).
Regardless of which thermostat is controlling the heating element, there is still the issue of overshoot - that is, just because the heating element has been turned off, there is still residual heat that is delivered to the boiler. There's another thread, either here or on CG, that gives the analogy of driving a car at 60 MPH then slamming on the brakes just as you hit the stop sign. I think that's appropriate.
Temperature surfing, as it relates to SBDU machines, is the dark art of guesstimating when in the on-off cycle to hit the "brew" switch and engage the pump. This is similar in concept to surfing for a HX, but different in execution. When temp-surfing a HX, you're still guessimating, but it's for the differential temperature the grouphead and the boiler based on the amount of water in the HX, the configuration of the grouphead, etc. Overshoot is less of an issue (at least, it is on my Rituale, because the boiler is controlled by a pressurestat with adjustable deadband, which seems much less tolerant of temperature fluctuation).
In a thermoblock machine, there may be merit in a temp surfing experiment, but I'd think that it would require some knowledge of the brew temperature. In my experience, 195F is too low for most coffees that I've tried - 200F ±2° has been the outer limits of acceptable taste. At around 195, just about everything was way too sour for my palate.
Best,
-s.
Your dog wants espresso.
LMWDP #288
