Expobar Brewtus IV vs Nuova Simonelli Musica
Postby Grit_dum on Fri Jul 01, 2011 3:41 am
I've read and learned so much from HB and found people here are extremely helpful.
This is the first thread I posted and hopefully to get some advises from people here. I'm an intermediate barista, who went through a short course, so I know a little bit of what it takes to make a good shot. I have changed 3 machines over the last two years and I've been happily with my Silvia & Rocky until now.
However, I have been thinking about an upgrade for sometime and I want to make sure that I will see big improvement in shot quality from Silvia and it is the machine that I can enjoy for sometime. I don't want to spend more than 2,000$ for the new machine, but it can be a slightly more for a good reason. I read so many reviews and I thought Brewtus IV is my choice, E61 group, DB boilers, rotary pump, etc, until I had an expert advise that E61 is an old technology that I shouldn't take for grant that is everything. Then I have been introduce to Nuova Simonelli Musica, which say to be a better choice to consider.
After read so much forward and backward before hearing this, I was so sure that I would like to go for E61 over other group style, DB Boiler over HX, Rotary pump over Vibrating pump. However, when hearing from a reliable source that Musica could make as good, or better shot than Brewtus then my brain processor is falling apart now. I would really like to hear opinion from somebody who try both machines before. Which one is better for home use that provide a great shot and perfect steam when need?
Small additional question, in case I change to either of this machine, do you think my Rocky Grinder still good enough for either machine.
Thank you in advance for any advise.
Grit_dum
Postby cafeIKE on Sun Jul 03, 2011 1:35 pm
Re Musica shot profile : PID thoughts
Does the person recommending the Musica own one, sell it?
Re e61 : The reason the e61 has lasted so long is its ability to make great espresso.
Re Rocky : it's a marginal espresso grinder. The grinder is more important than the machine. Consider upgrading it first.
cafeIKE
Postby Grit_dum on Tue Jul 05, 2011 8:41 am
Thanks, cafeIKE.
The person own and try several top end machines including Speedster and GS3. He has Brewtus III in stock as well, but recommend to wait for Musica. That's why I wonder, as how a cheaper HX machine will pull a better shot than a good DB E61. I would be interesting to hear opinion from those who try both machines.
About Grinder, do you recommend that I would see noticeable different changing to Macap M4?
Grit_dum
Postby cafeIKE on Tue Jul 05, 2011 11:01 am
The adjustability of the MC4 is much better than the Rocky.
I'd look at a used Super Jolly or the new Quamar M80 as they give more bang for the buck.
cafeIKE
Return to Buying Advice
