by Sleepless on Wed May 23, 2007 7:37 pm
The first few days learning how to use the La Spaziale S1 VII have been interesting. My old machine is a Saeco Classico, and I have been using a KitchenAid Proline grinder. I have never used a bottomless portafilter before, and was eager to see how my technique looked.
I should have put on rain gear, because coffee sprayed all over the place! I had channeling like crazy. So, I gave up on the Kitchenaid, and went to my Mazzer Super Jolly. Still no luck. I tried to find the right grind, but was still getting coffee spraying out (granted, this could be my tamp technique). Now, to break in my Macap MXKR... I had wanted to introduce only one variable at a time, but I was wasting coffee and making a mess of my basement setup. I had followed the Macap instructions on setting up for espresso - and got the finest powder - talc like in fineness. I knew it would be a waste. but just for the heck of it, I tried to pull a shot, but no dice... the machine choked. I opened up the grind three quarters of a turn of the adjusting ring (this takes a bit of time with the worm gear) and voila... almost perfect, and the pour looked like some of the pictures I have been drooling over for a year. The MXKR does a great job grinding, and I have had delicious, repeatable shots these past two days, but I hate that the chute clogs up so much. I have taken off the finger guard and have a dental probe that I use to scoop out the clumps of coffee sitting there. I also end up throwing away quite a bit of coffee (I vacuum out the doser after each shot).
I will try to take some photos and get them posted here.
- Steve
