mhoy wrote:George: I'm in Sunnyvale (which is nearby Campbell), which distributor did you place the order with? I'm about 2 weeks from my kitchen remodel and I'm very curious about the Claris solution.
Mark
Hi Mark,
The retailer is Dong Vinh Restaurant Equip & Supplies, on Monterey Rd. between Curtner and Stauffer.
The head unit is $75 and the M filter $120. A bit on the expensive side but if it works as expected it will be about the same as the Crystal Geyser gallon bottles I use (based on a years worth of use). Hopefully if the Claris catches on, filter prices will go down.
So ... my turn for Guinea Pig mode. You're certainly welcome to stop by, check it out, run some tests, etc. And I do want to check out your T1 someday!
George
