Thank you for taking the time to read this and thanks in advance for any help.
Back in the mid 90s I worked at Starbucks as a barista, it was so long ago that it was before they automated everything and one actually did have to have some technique to pull a shot well. So back in the day I did know how to pull shots, and have been disappointed with home machines but have been unwilling to drop the cash to get better results.
My home espresso background is that several years ago I was given a DeLonghi espresso machine which pretty much sucked but I used it every day anyway. It was super light and in order to even get the portafilter in it I had to essentially wrap my entire body around the machine while turning the portafilter in, it was rather comical actually. Anyway, that machine lasted about a year, was replaced twice under warranty for a leaky gasket, and the third time it quit I upgraded to a Cuisnart espresso machine which was much better, I could actually put the portafilter in without much physical effort, pretty fun, really, and the espresso tasted MUCH better and even had crema and didn't taste burnt. Yay. So a few weeks ago the Cuisnart suffered some sort of electrical problem and was replaced under warranty, the replacement arrived and didn't work out of the box, the second replacement arrived but I haven't opened it yet because I decided to try to find something that might last a lot longer and give me better espresso than my current setups have been.
So here I am. I've been using a french press since the Cuisnart died and I'm really missing my daily latte. I dream about it all day long and make trips to coffee shops now, I've never done that before. I've been reading and re-reading posts and I think I've decided that I want an HX machine, but I'm afraid I'm over buying. I should mention that while I make lattes daily, I've never used the steam wand on either machine I've previously owned because there wasn't really enough power, I just heated the milk in the microwave. I'm sure I'm going to barista hell for that, but there wasn't a better choice.
I started this journey by thinking that I'd get a Silvia/Rocky combo, then a PID Silvia because I'd like some temp consistency right away while I'm working through learning how to pull a good shot at home, then I decided about the PID Le'Lit because it's supposedly faster warm up than the Silvia.
So then I read more and decided that since what I really make is lattes, and rarely straight espresso, maybe something that's better for steaming milk and pulling shots is really what I want, so now I'm stuck on the Bezzera BZ02SDE at 1st Line. I'm leaning towards the Baratza Virtuoso Preciso grinder. I know that Virtuoso wasn't greatly reviewed for espresso, but it looks like the new burrs on the Preciso work pretty well. If they had the Le'lit in stock I'd probably just go for that. (Does anyone have thoughts about the Anasco I-Mini? It was another in the thought process.)
Basically what I want is a machine that will last, isn't difficult to maintain, and will be easy to use (after the learning curve) in the morning when I'm in a hurry. (By difficult to maintain, I mean I don't want to have to take it apart and do repairs or add any aftermarket things, I wouldn't PID a machine myself for instance.) I don't have a ton of morning time which is another reason I'm leaning towards the Bezzera, I want to be able to crank out drinks for me and my husband. I don't really want a hugely long warm up time. What can I say, I'm not very patient in the mornings.
Anyway, thanks for letting me air my thoughts, and any advice is greatly appreciated!
Julie
