Double boiler espresso machine recommendation - Page 9
Postby sjjan on Sun Jan 18, 2009 5:06 am
luca wrote:I really don't understand the constant repetition of the "fact" that the vibiemmes have "high quality" components and the expobars do not ... particularly in the case of the dual-boiler versions, which now both seem to use temperature controllers from the same manufacturer.
Frankly, I suspect that it's as simple as people perceiving the VBM as a luxury good because of its higher price and the Expobar as shoddier because it is cheaper.
The insulation of the machine (not the boilers as such) is much better with the Vibiemme than the Brewtus III. I ran them side-by-side and the Vibiemme was very quiet (vibration pump version) and the Brewtus III made more noise. Then the thickness of the boiler walls was according to the sales person thinner on the Brewtus than on the Vibiemme. Performance-wise I did not notice a difference other than the noise level and outside finishing, so due to the huge price difference I opted for the Brewtus-III. I could not see how less noise and a little better outside finish could justify such a huge difference in price.
Sjoerd Jan
sjjan
Postby sjjan on Sun Jan 18, 2009 5:10 am
Michal wrote:Is the preset offset correct on the Brewt?
Yes it is quite accurate. I measured the temp with the SCACE thermofilter and it corresponds with what is on the display to within 1 degree. Also the temp stability was very well (also on the Vibiemme) giving very consistent shots.
I just brought the pressure down yesterday night adjusting the OPV as it was set to 11 bar and now is back to about 9.5 bar.
Sjoerd Jan
sjjan
Postby HB on Sun Jan 18, 2009 9:40 am
Have you seen them side-by-side? It's easy to see the different choices in components and materials. The OPV is an obvious example:
Nylon versus brass plunger adjustment
Note: The OPV pictured on the right is actually from Chris' Coffee photo of the Quickmill Andreja Premium, but the Vibiemme uses the same one. Chris' Coffee makes a big point of the fact that others use a lower grade stainless steel. I don't think it will lead to the Expobars rusting away, but it is true that the higher grade stainless looks more silvery and shinier, if that matters to you.
sjjan wrote:I could not see how less noise and a little better outside finish could justify such a huge difference in price.
Look at Elektra's prices (at least in the US). :shock:
Postby Michal on Sun Jan 18, 2009 11:14 am
I heard from Todd at WLL that the OPV has been upgraded in Brewtus III. When I get mine I'll open (him/her) up and take some pictures. With thinner boilers, at least if uninsulated, they will respond to changes in temperature faster. I hope the III-R is quiet, than again I doubt Kony will :(.
Michal
Postby HB on Sun Jan 18, 2009 11:18 am
Michal wrote:With thinner boilers, at least if uninsulated, they will respond to changes in temperature faster.
Hmm-m, when you can demonstrate this advantage, let me know. Otherwise it sounds like creative marketing-speak. :wink:
Postby Michal on Sun Jan 18, 2009 11:22 am
In the case of the Brewtus it's untrue because the boilers are insulated. If the boilers are thinner they retain less heat. Lets say you put a piece of tin foil in the oven and a thicker baking tray at 400 for an hour. Take them both out of the oven and you can almost instantly touch the foil but the tray will remain hot for a few minutes. We should test it at the CCC meeting on friday :D.
Michal
Postby sjjan on Sun Jan 18, 2009 12:28 pm
I took some pictures yesterday of the internals of the Brewtus III (see bottom part of http://www.home-barista.com/espre...afilter-t9530.html). The OPV has indeed been updated and is not of plastic anymore (the adjustment screw). I have never seen the inside of a Brewtus II, so I cannot compare.
Sjoerd Jan
sjjan
Postby HB on Sun Jan 18, 2009 12:38 pm
Michal wrote:If the boilers are thinner they retain less heat.
I agree with your "armchair engineer" analysis, but remain unconvinced it makes any measurable difference and even less convinced anyone could taste the difference. That's the risk in thinking of espresso machines as an engineering problem to be solved rather than a means to an end, something I have been guilty of many times in the past.
Postby RapidCoffee on Sun Jan 18, 2009 1:46 pm
Michal wrote:In the case of the Brewtus it's untrue because the boilers are insulated. If the boilers are thinner they retain less heat. Lets say you put a piece of tin foil in the oven and a thicker baking tray at 400 for an hour. Take them both out of the oven and you can almost instantly touch the foil but the tray will remain hot for a few minutes. We should test it at the CCC meeting on friday :D.
Think this through. Suppose you had a liter of water at 250F, enclosed in tin foil. Could you handle that? It's not the boiler, it's the contents.
Uninsulated boilers radiate heat. Although the type of metal and thickness may affect the rate of radiative transfer, this will be minor compared to insulating the boiler. The reason for using thicker metal in boilers is strength, not insulation.
John
RapidCoffee
Postby malachi on Sun Jan 18, 2009 2:08 pm
for 99% of buyers - none of these machines will be the gating item
thus the choice is largely an emotional, personal and somewhat irrational one
wrapping this reality in technical detail doesn't change the fundamental truth
malachi
PreviousNext
Return to Buying Advice
