Double boiler espresso machine recommendation - Page 3
Postby MDL on Sat Jan 10, 2009 1:36 pm
I have used both a single boiler Vibiemme and the Vivaldi II (I have owned the Vivaldi for almost 2 years). The Vibiemme is huge (very deep) and I don't like messing with the E61 flushing; that is just my personal preference.
Plumbed in and rotary pump are great; no filling or cleaning of tanks and quieter less obvious noise.
In terms of plumbing off the refrigerator, most refrigerator connections that I have seen are 1/4". You can plumb the Vivaldi with 1/4" line, but my understanding is that 3/8" is the preferable way to go (and what I used) so that you don't limit the pump.
As noted by others, you also want to use water that is not hard (if your water is soft great, otherwise you need to soften with either ion exchange or reverse osmosis) and to have a pressure gauge and regulator on the system. All of this can be done from a "T" off the refrigerator line if the line is large enough to handle everything.
I am sure that any of these 3 machines can make great coffee for you. I like the looks of the Vivaldi (as mentioned by others) and also really appreciate the double boiler, plumbed in rotary pump.
Good luck,
Mark
MDL
Postby Michal on Sat Jan 10, 2009 1:36 pm
I was thinking about the Domobar Double Boiler not the HX. I'm glad to hear your liking your Vivaldi II i'm really thinking about it.
Michal
Postby bernie on Sat Jan 10, 2009 3:59 pm
zin1953 wrote:Bernie, you're evil! :twisted: :wink: :mrgreen:
More than evil. I've placed an $1800.01 bid. One never knows. Just out of curiosity, I wonder how much a La Marzocco AV2 would be worth to folks on this site? How much would you pay for a nice, used professional 2group to put in your kitchen?
Bernie
bernie
Postby sweaner on Sat Jan 10, 2009 5:43 pm
$1800.02! :wink:
Scott
LMWDP #248
Man does not live by coffee alone...we need beer too.
sweaner
Postby RapidCoffee on Sat Jan 10, 2009 5:58 pm
JohnB. wrote:I see little difference between boiling water in a kettle or on a stove & drawing it from your machine tap as long as you use the steam boiler regularly.
Presumably you mean, as long as you regularly draw off hot water. Well, to each his/her own.
John
RapidCoffee
Postby JohnB. on Sat Jan 10, 2009 7:41 pm
RapidCoffee wrote:Presumably you mean, as long as you regularly draw off hot water. Well, to each his/her own.
Correct on both counts. I edited my post to make what I was saying a little clearer.
LMWDP 267
JohnB.
Postby RapidCoffee on Sat Jan 10, 2009 9:10 pm
Michal wrote:So my question still remains. If you make 6-10 milk drinks a day, can plumb it in, and have the option of Alex Duetto, Vivaldi II, Domodouble Rotary, or Brewtus 3-R, which would you get?
<11' pole>
All these machines, as well as most prosumer E61 HX boxes, would suit your requirements very well. At some point it boils down to personal preferences. As others have said, you'll get better results by focussing on the grinder. The Mini, with its 58mm flat burrs, is the "Mini-mal" grinder I would recommend for your class of espresso machine.
The Spaziale has its strengths and weaknesses. The nonstandard 53mm grouphead is one of the weak points, especially for someone who already owns several 58mm PFs, baskets, and tampers. The boilers are uninsulated and not PID'd. OTOH the asymmetric boiler sizes (2.5L steam and 0.5L brew) make a lot of sense, the 2.5L steam boiler is the biggest of the bunch, and will froth like a locomotive. Along with the Brewtus, this is the only home DB with a long proven track record, and it's slightly less expensive than the VBM or Alex offerings. It's also the only machine that I have any significant personal experience with.
All machines have their positive and negative features. The Brewtus is the least expensive, but Expobars have a history of quality control problems. The VBM DD is apparently still having v1.0 issues. The Alex Duetto looks promising but it's also a relatively new entry. Others can jump in and tout their strong points.
</11' pole>
John
RapidCoffee
Postby Endo on Sat Jan 10, 2009 9:58 pm
RapidCoffee wrote:The nonstandard 53mm grouphead is one of the weak points, especially for someone who already owns several 58mm PFs, baskets, and tampers. The boilers are uninsulated and not PID'd.
I too was worried about the 53mm basket. (I owned only 58mm prior). In actual fact, it turned out to be a "non-issue" since the 58mm PF, basket and tamper usually gets sold with the old machine. The only thing you might get stuck with is a naked PF, but I sold this at a good price as well when I sold my Silvia.
After using both the 58mm and 53mm, I must say the 53mm seems to work better. The taller puck seems to reduce side channeling. Also, the reduced diameter means the puck edges will see less thickness variation due to an unlevel tamper. The LaSpaziale philosophy was to start with a blank piece of paper and choose the best "aspect ratio" to produce the best taste. I think they chose well. Note the other new machine on the block (Dalla Corte Mini) also uses a smaller diameter.
I wouldn't insulate the boiler since the machine runs cool and the small amount of heat is used to heat the cups on top. Actually, some people are putting a towel on top to increase the heat to the cups.
As far as the PID goes, LaSpaziale uses proprietary temperature control logic on a controller board and LaSpaziale even does firmware upgrades. It's not an off the shelf $50 PID like the other machines.
"Disclaimer: All troll-like comments are my way of discussing"
Endo
Postby Rybolt on Sat Jan 10, 2009 10:09 pm
Endo wrote:It's not an off the shelf $50 PID like the other machines.
Wow, please, do tell me where I can get a Gicar PID for $50, that's a helluva deal.
Rybolt
Postby Endo on Sat Jan 10, 2009 10:52 pm
Sorry, $50 PID in a $100 Gicar project box. :lol:
Endo
PreviousNext
Return to Buying Advice
