Michal wrote:Okay, I am reconsidering the Vivaldi II and after some research it is pretty much at the top of my list (go figure). My main concerns are quality of machine and quality of coffee. If it makes better coffee than Alex Duetto and DomoDouble than I'll go for it. Is there a triple shot basket for it? How convenient is the hot water? Does the steam arm have good mobility and if not does it impair its steaming ability? For me plumb in or not isn't too big of a deal. I can go either way but obviously plumb is more convenient. Where does the water line connect? Will it work off a refrigerator connection split into 2? Does anyone have pictures of the gray side panels? Can I possibly ask more questions?
I'm sure you can
but you may have to find the answers for yourself. Some
opinions:
1) Nobody can convincingly argue that one of these machines makes "better" espresso. The advantage of a DB is that it delivers brew water at a fairly precise temperature setting, but even that does not guarantee "better" espresso. 1C resolution is fine for mere mortals. A good HX machine will also meet your requirements of "6-10 milk drinks a day".
2) The S1 is a nice looking machine and has a much longer proven track record than the Duetto or DoubleDomo. Chris Coffee is an excellent vendor. Hard to go too far wrong with this machine. The 53mm filter basket size does limit your options, but I wouldn't worry about triple baskets. Just pull two doubles if you want a big gulp latte.
3) Get an electric kettle for hot water. The hot water tap gives you water that's a) too hot and b) been sitting in the boiler for too long. But yes, it's available on the S1 if you insist.
4) Plumbed espresso machines are great. You can tee off the refrigerator line and call it good, but I'd recommend a pressure regulator and a filter/water softener as well (available from CC).
Some great advice on this thread. Good luck with your decision.
