by JmanEspresso on Wed Feb 24, 2010 11:28 pm
Yes, the strips from Chris will be sufficient for them to suggest a setup for you, but I do suggest going with the kit Nicholas suggested for a bit more information.
If you're plumbing in, and dont need a softener, I think it wise to still put a carbon filter for particulates.
Also.. Keep in mind that you dont HAVE to connect the Vivaldi II to a water line.. You can run it off of a 5Gallon Water Bottle and Flo-Jet setup. Thats what I currently have set up. ITs like having a REALLLLLLY big water reservoir. Even with the amount of water I draw out of the hot-water tap, I still only fill up once a week. The Flo-Jet is about $100, and if you just buy one 5gallon bottle, it can be filled up from your tap(instead of subscribing too a water delivery service). Then you add an Accumulator to smooth out the pressure from the Flo-Jet($50), and you have yourself a plumbed machine, "on your own terms".
Im going to be moving soon, so I thought it silly to run the lines and whatnot, just to take them back out in a few months. So, when I move, I will be plumbed in.. but to be honest.. this setup is nice. I would definitely take this setup over a pourover/vibe pump machine, but like I said earlier, if vibe/pourover is the only realistic option, then thats what I would own.
