Concept Art (aka Rexroth) Steam Group Brush
Postby boar_d_laze on Fri Jun 17, 2011 9:35 pm
Just ordered one on a whim as a Father's Day Present for myself. Any relevant advice?
BDL
boar_d_laze
Postby outrigger on Sat Jun 18, 2011 2:43 pm
Happy Father's Day, BDL, which one did you order?
This:
http://www.concept-art.de/OXID_ESHOP_CE...Brush.html
or this:
http://www.concept-art.de/OXID_ESHOP_CE...usive.html
or this:
http://www.concept-art.de/OXID_ESHOP_CE...Basic.html
or this:
http://www.concept-art.de/OXID_ESHOP_CE...ziert.html ?
IMHO, the "Exclusive" is the only one I did not burn my hand. Cheers!
outrigger
Postby boar_d_laze on Sat Jun 18, 2011 3:30 pm
This is the one: http://www.concept-art.de/OXID_ESHOP_CE...Brush.html
Get it clean with the power of steam!
BDL
boar_d_laze
Postby TomC on Mon Jun 20, 2011 8:42 am
Fresh out of the roaster: Hawaii Ka'U Typica, Ethiiopia Gedeo Worka, El Salvador Kilimangaro WP
Next batch: Nothing yet!
TomC
Postby Clint Orchuk on Mon Jun 20, 2011 9:11 am
Brilliant idea.
Clint Orchuk
Postby duke-one on Sun Jun 26, 2011 1:41 pm
I saw a very nice knock box on the web site listed above but could not find it in the US. Does anyone know the brand name or a state side supplier?
Thanks, KDM
duke-one
Postby TomC on Tue Jun 28, 2011 2:56 am
That looks like the Porsche of knock boxes. Very cool and the feet look plenty substantial if they are solid rubber( no inner posts).
TomC
Postby boar_d_laze on Tue Jun 28, 2011 8:08 am
www.idrinkcoffee.com carries them. Free shipping, too.
BDL
boar_d_laze
Postby boar_d_laze on Fri Jul 01, 2011 4:17 pm
Update and brief review:
Received it. Put it together. Hooked it up. Tried to use it (dry steam) but the silicone (vinyl?) tube blew itself off the hose barb (not the steam wand). Ghetto rigged it with a twist tie, and all was secure. Have subsequently upgraded to three (count them, three) plastic wire ties, for that "'Klassy' with a capital 'K' effect." Should you want to soften the steam-punk-kludge look farther, you could use high temp sealant.
People here and in other fora seemed concerned about the tube possibly blowing itself off the steam wand. If you're not careful, it does. However, as long as the silicone tube is pushed up close to the wider part of the tip, it will not come off, at least not on my machine. Unfortunately, the higher up the tip you push the tube, the more of a beast it is to remove from the wand. You may have to pull fairly hard, which means supporting the steam wand so as not to pull the wand from your machine, but (surprise surprise) steam wands get hot. If it's really stuck, let the wand cool before removal, run some fresh steam through it so the heat soften and expands the silicone, then use two towels.
Bottom Line:
This thing REALLY REALLY works. It leaves the group raceway, gasket, and screen immaculately clean; and of course you can use it to clean anything it can reach. On the other hand, because it takes so much time to set up and put away you'll probably want to reserve it for end of the day and continue using your regular brush between shots for those inter-shot times you want to brush. It's a large PITA.
Worth it? If you're seriously into clean, AND you can afford a $75 brush, AND you enjoy complication, AND you like buying gifts for your espresso machine, it is. Otherwise, no.
I like mine.
BDL
boar_d_laze
Postby boar_d_laze on Tue Jul 19, 2011 10:38 am
Update (sort of):
Used daily, it's not that much of a PITA (or at least you become resigned), and really does make a difference. My group and screen stay visibly cleaner between Full Circle cleanings than they did with a regular brush. The machine seems to reveal more in the cup, but I can't promise the connection isn't post hoc propter hoc. Pass the Kool-Aid.
Blast it clean with the power of steam,
BDL
boar_d_laze
Return to Buying Advice
