I actually already own a K10 WBC, and it's definitely true that you waste a good deal more coffee than with a basic flat burr grinder, mainly because of the large amount held in the grind chamber. I have several espresso sessions every day, and having to grind out 10g each time does add up. I also find that the last couple of shots worth of beans tend to produce poor espresso, because without the weight of the beans on top, the grind changes quite a bit. Updosing a little helps, but my normal dose is almost at the limit of what the basket will hold, so I can only add so much. I know the Robur has an auger to feed beans to the burrs. Does it help with this issue? Also, is the grind retention any better than the K10 WBC?
I'm just mulling over the thought of purchasing a Robur. It seems like it would be a rather pointless upgrade from a K10 WBC, but it's often in the back of my mind. The Compak grinders don't give quite the same impression of rock solid construction and dependability, but I know they get the same use in a commercial environment, and it is a moot point for a home user like me. It's nice that Compak listens to its customers and adds useful features so quickly, but it would also be nice if they updated the damn product manuals to reflect these changes!
I received word from Espresso Parts that the price increase is indeed correct. The basic Robur now costs over $3000! I guess now is the time to order a Robur if you want one
