by luca on Wed Feb 06, 2008 9:34 pm
Hi All,
The plot thickens.
We just bought half a dozen new mazzers at work and there seem to have been some changes to the dosered Robur. First, there is now a blade above the conical burr set. Our speculation is that it is really there to chop up beans that might otherwise stick in the throat of the grinder, rather than to contribute to grind quality. Personally, I have never really seen beans stick in the throat of a Robur, but, then again, I don't use Roburs that much. I guess that maybe some really dark roasted and greasy maragogypes might get stuck and the extra blade might solve that problem. Second, and perhaps more importantly, when pulling the doser lever at the usual speed, the coffee drops straight down into the portafilter. If you pull relatively slowly, there is a small amount of left shoot. If you pull insanely quickly, the coffee seems to bounce against the inside wall of the dosing chute and a tiny bit actually shoots right!
Cheers,
Luca
