Christmas Gift - Better Choice for a Beginner. - Page 2
Postby jedovaty on Fri Dec 16, 2011 2:37 pm
Hi there,
I would do not get a hand grinder with what you've said, especially your latest follow up post about having talked too much.
I'd recommend saving up for a refurbed baratza grinder, and get a pourover or french press setup. That's how I got my GF into it (I'm from a similar ilk, I never drank coffee), and then opened up to espresso later. You might also consider a mypressi twist. They are small, relatively inexpensive, and fairly user friendly. Drawback is that you need to use another gadget to get steamed milk (I use the $2 ikea produkt or a stovetop steamer).
jedovaty
Postby Charbucks on Fri Dec 16, 2011 5:13 pm
I was in a rush this morning, so I pulled out my old coffee maker (an Aeropress) instead of waiting for my shiny new CC1 to warm up (it's great, btw). I bought the Aeropress three years ago, back when I thought oily beans meant higher quality. It's had pretty much daily use since then (along with a Spong #1 grinder that's been in my family forever), and I've learned a lot about the different flavours of coffee, and I would definitely say it sucked me in to this world. However, I haven't used it in the past 2 weeks since the CC1 + Vario arrived.
I was rather impressed by my return to Aeropress coffee. For 5% of the price, it provides at least 80% of the quality of flavour, and it's super quick to use and clean up. Boiling water takes the longest time (especially since I don't have a kettle), but after that it was less than 3 minutes to grind, press, and rinse.
If you're still considering something for your girlfriend, maybe think about an Aeropress plus grinder. My boyfriend had a Capresso Infinity that does a good job if you don't need to grind too fine, and it's about $100. For $130 all together, it's a pretty good setup and won't make her feel like she needs to use it every day to justify the expense.
Charbucks
Postby Randy G. on Fri Dec 16, 2011 7:54 pm
Baratza grinder + Espro Press. If fed quality coffee it will make a beverage better than any traditional French Press, and it is easy to use. It's a five-star device in my opinion that makes the French press obsolete.
Espresso! My Espresso!
Randy G.
Previous
Return to Buying Advice
