As Chris Nachtrieb mentioned in the Marketplace, he sent me the
Macap M4 stepless grinder to update the
Feature Spotlight on Espresso Grinders. It's been about a year since I evaluated the stepped Macap M4, so tonight I would like to note some observations while the differences between my usual Mazzer Mini and the new Macap are fresh in my mind.
Appearance
The Mazzer almost looks stately next to the flashy chrome Macap. The exterior paint and the chrome comparison isn't the only visual difference: The Mazzer uses matt-finish black plastic and the Macap uses plastics with a high-gloss finish. Tinting the Macap's hopper and doser was a good idea, not only because reduces the beans' exposure to light, but it also hides scratches and smudges. The Macap has a black plastic trim piece over the metal adjustment collar compared to the Mazzer's solid chrome-plated metal ring; black slotted vent covers are on each side of the Macap. The Mazzer has a "solid metal" look to it.
Ergonomics
The Macap's doser arm has a very springy, fluid feel to it. The "clack" at the stop is crisp, but louder than the Mazzer. As noted in the review, the Macap sweeps very cleanly. However, I've modified the Mini to best the Macap's sweep efficiency by a hair:
Increase sweep efficiency by adding tape to the trailing edge of the Mazzer's doser vanes
The Macap's portafilter rest offers no ledge for grounds to collect; the distance between the portafilter rest and the bottom of the doser is tighter for the Macap than the Mazzer. Trivial point, but I found it interesting how accustom I've become to the placement of the doser handle, power switch, and portafilter rest. Overall great ergonomics. The switch cover, however, is annoying. The rocker power switch has a clear rubbery cover over it, presumably to prevent the grinder for accidentally being started by a casual bump against the switch. A brief visit with Mr. Exacto-Knife would cure that annoyance (kidding! do not disable safety devices). Although some rail against the timer switch on the Mazzer, I don't mind it. It turns back easily to the off position, and it prevents the grinder from running unattended.
Macap was the first to introduce the "shorter" hopper so their grinder would fit under US cabinets. I suspect some buyers went for the Macap over the Mini simply for that reason; Mazzer followed suit a few months later by introducing their own vertically-challenged hopper (now the standard). The major difference between the two grinders remained the stepped versus stepless settings and I frequently wondered why Macap didn't introduce a stepless sooner.
Below is a picture of the stepped M4 adjustment collar with the "trim ring" removed:
The setting pin locks into holes drilled in the bottom of the metal adjustment collar
Seeing the new stepless version, I see they neatly modified the existing model by replacing the plastic trim ring with a toothed one and then bolting the worm-gear adjustment onto the top of the grinder along the backside (Macap will be at the SCAA conference and I'm sure enthusiasts in attendance will nag them to offer a "retrofit kit" for the M4). I'll figure out how many finger turns of the stepless correspond to one increment of the stepped M4, but my guess is that it's around one turn. I remember the worm drive on the Cimbali Junior being a little finer, though I don't have the two side-by-side for direct comparison. In any case, I found it easy to make minute adjustments to compensate for pour time differences of a couple seconds.
Bottom line: It's a keeper.
(Sorry for the brevity, I'm fighting a cold and nasty cough...)
