by AndyinTexas on Sun Dec 12, 2010 10:50 am
Thanks for the thoughts. One further question. Is the mini-hopper both easily removable AND does it have (as I believe most hoppers have) a retractable plastic "tab" at the bottom of the mini-hopper that allows you to keep beans in the hopper when removed from the base of the grinder.
The reason I ask is that it seems to me that if that were the case, I would be able to switch seamlessly between single dosing and using the mini hopper when I had company - in each case moving the base out from under the top cabinets to the front part of the counter top. It would also give me the option (preferred by Mrs. AndyinTexas) of keeping nearby, but not attached to the base of the grinder, a small amount of beans stored in the mini-hopper, and just bringing out the mini-hopper and pulling the base of the grinder to the front of the counter from under the top cabinets each morning when pulling shots.
Thanks again.
