avamtel wrote:Either a Used Vibiemme Super HX Tank Domobar (2006 manufacture demo) or a new Bezzera BZ02S or Bezzera BZ07spm. Can't believe I'm considering spending this much (about 1,000)
I assumed in earlier posts your total budget you want to allocate to espresso/cappuccino is higher than that based on the "either/or."
Depending on the discount given on the VBM, I would start with that one. And, with an espresso machine you can start brewing, potentially buying coffee ground for espresso (cursing in the church, sorry). The other end of the "either/or" does not provide a route into coffee until you have the espresso machine.
avamtel wrote:want to be able to serve 6 cups or more of cap. when we entertain. Started by looking at the Silvia but that purchase might lead to rapid onset upgraditis.
A series of six seriously loads your machine and you should stay away from machines that have to be switched between brewing and steaming modalities but can do both at the same time instead.
Really, upgraditis - and unnecessarily fast depreciation are around the corner if you did this.
avamtel wrote:The Vibiemme looks awesome but concerned about used aspect.
As I explained earlier, I would not worry about this if the machine looks like new and a fair discount is given I gave a few pointers for haggling. and there are a few more, but basically they need to really give a very good discount and you are fine.
If you only do "cappas" then you might be less finicky about the espresso, actually.
Initially.
Try to get to a point where you step into the home-barista world with predictable well-documented equipment.
Apply upgraditis to the coffee and your taste in it, not necessarily the HW.
I do not know the Lelit grinder, but if Jim points to it, you have a really good start.
But then, talking 2nd hand, you might be able to source a good 2nd hand _big_ commercial grinder and if hubby is into DIY a bit he could refurbish it himself, making sure the correct burrs go into it, etc. (read the Titan Grinder Project pages on home-barista to get an idea of what this is all about.)
Regards
Peter
