another_jim wrote:It's the direction that screws the burr out.
You bought a used grinder, with no instruction manual, and you don't know which direction coarsens the grind. You probably won't be able to make this work unless you find someone local who knows espresso gear. There's only so far you can go by getting information on a forum, and learning how to fix and maintain used espresso grinders when knowing nothing about them is a step too far.
Touching...
I didn't know a lick when I started out either. I shadowed this forum for over a year without joining because of the strong potential of that kind of response.
Then I decided I didn't give a **** and that I would post, ask questions and hope someone would be kind enough to want to explain things to me on here. Luckily that happened.
