www.baratza.com: skilled in the art of grinding
Brasilia Cappuccino or Nuova Simonelli Oscar?
Postby SimonSoCal on Sun Dec 27, 2009 3:33 pm
I tried to search on the maker of Brasilia Cappuccino but no have much data.
Wonder if it is a very old brand or it just not popular.
I ran into one review but I need to do a little more homework.
What is ULKA pump vs. Procon pump? And why would it makes a different in espresso if the beans are less than "fresh"?
* I typed ULKA and it shows alot of descriptions but not the basic info of meaning ULKA and its purpose. [sorry for being a newbie :oops: ]
**As you can see I'm still debating on the type of machine for my home use. Currently my Starbucks Barista is not giving me a consistent brew temp. My espresso [with the Mazzer SJ] taste bitter & sour sometime and some taste better. All under one sitting.
SimonSoCal
Postby SwingT on Sun Dec 27, 2009 3:47 pm
If they make a consumer model, I am unaware of such - it may be a Brasilia commercial machine
If this was a Craigslist or ebay listing - they may mean a Brasilia machine - and are calling it a cappuccino machine simply because of the steaming ability.
The most common model, I believe is DEL1 - is a plentiful machine marketed also under I think several machines.
Dependiing on price and condition, it could be a decent machine for home use. I almost bought one for home use, price wasn't low enough.
a link to Del 1
http://www.chriscoffee.com/products/foo...tofinodel1
SwingT
Postby SimonSoCal on Sun Dec 27, 2009 8:04 pm
SwingT,
Hi, I'm referring to this Brasilia
http://www.caffesociety.co.uk/brasilia-...ccino.html
Any suggestion is greatly appreciate
SimonSoCal
Postby zin1953 on Sun Dec 27, 2009 8:30 pm
Simon, perhaps you could explain why you are looking to buy a machine in the UK when you live in Southern California . . .
zin1953
Postby mgwolf on Sun Dec 27, 2009 11:20 pm
Simon,
ULKA is a common brand of vibe pump used in pour-over machines. They are relatively noisy and inexpensive but work fine. The Procon is a common brand of rotary pump which are found most commonly on commercial machines that are plumbed in. They are more expensive, more heavy duty, much quieter, and generally need to be hooked up to a continuous water supply (plumbed-in). I'm also curious for the answer to Zin's question - I'm not sure if the Brasilia Cappuccino is available in the States. As a newb, it would be helpful for you to read the Guide to Espresso machines and similar articles found on this website. Michael
mgwolf
Postby caeffe on Mon Dec 28, 2009 12:27 am
SimonSoCal wrote:I tried to search on the maker of Brasilia Cappuccino but no have much data.
ULKA vs Procon - ULKA pump is a brand of a vibratory pump; similar to the one in your Starbucks Barista. Procon is a brand of rotary pump - the pump will not make that vibrating noise, it is quieter. Most machines with a rotary pump imply a direct connection to a water supply whereas vibe pump machines will have a reservoir in the machine that will supply the water.
BTW, you're failing you're homework. You need to re-read Espresso 101 and possibly quite a bit of the FAQs http://www.home-barista.com/faqs-and-fa...somachines :P
LMWDP #162
caeffe
Postby SimonSoCal on Mon Dec 28, 2009 1:29 am
Thank you for all your replies.
Jason,
I'm not making a purchase from England. Just wanted locate a photo for SwingT
zin1953 wrote:Simon, perhaps you could explain why you are looking to buy a machine in the UK when you live in Southern California . . .
<image>
Caeffe:
I did do my homework but perhaps not as quick learner as some of you. I did not see any association of ULKA as acronym(as brand) for vibe pump. Perhaps, I will review once again and look for a directory of acronyms and references.
Do appreciate you guys taken the time to reply.
SimonSoCal
Postby zin1953 on Mon Dec 28, 2009 10:26 am
zin1953
Postby HB on Tue Dec 29, 2009 2:07 am
SimonSoCal wrote:I did not see any association of ULKA as acronym(as brand) for vibe pump.
Mark wrote a good espresso glossary, but I'm not aware of an exhaustive acronym listing. You can pick up many via the context when searching. For example, searching on threads with "ulka" in the subject yields good matches. Forum search tips offers other self-service suggestions.
Return to Buying Advice
