http://www.imdb.com/title/tt0091203/quotes?qt0337068
Cheesy movie quotes aside, I'm finalizing my decision between these 3 machines: Bezzera BZ07, Vibiemme Junior DB or La Spaziale Vivaldi Mini.
I drink mostly espressos (born and raised in Italy, so that's a given), but I need good steaming capacity for entertaining. If it were for me only, I'd go with a Silvano, but I'd rather get the right machine from the start and crank out awesome cappuccinos when having a party.
I can't use a plumbed-in version, and would like to use it on a timer
As for my finalists, those are very different machines, and here's my logic:
At $1099, the Bezzera BZ07 is hard to rule out. A "different" HX machine, seems to address most of the HX/E61 weaknesses and require shorter cooling flushes (or close to none at all), based on what I read. Seems well built, I like the look (better than any of the other machines here) and the small footprint, and I love the fact that the full mechanical/electrical diagram is available online. There's also a PID model, if I wanted to thinker with the temperature easily. Can be put on a timer easily. Can buy the volumetric doser versions if I wanted (but I don't think it's worth the extra money for me). On the con side, uses a non standard portafilter, even if the filter itself is 58mm. Possibly hard to refill under the counter due to the narrow. Unsure about long term availability of spare parts, as well, as there doesn't seem to be as big a community around it
Vibiemme Domobar Junior Dual Boiler. The "real" E61 group, dual boiler guarantees much better temperature control (and ability to use only the brew boiler most of the times), can be PID-ed (or you can even get a PID-ed version from Hitechespresso for $1,550. BTW: if you use that setup can you please share your impressions?). Standard parts, easy to service and to thinker with. Kinda like the looks, and same small footprint as the Bezzera. Can be put on a timer easily. Easier than the BZ07 to refill when under a counter, but not great either. No real big cons, apart from a higher price ($1,469) for what seems not much more than a BZ07 in the end. But I might have found a nice used one for roughly the BZ07 price, which is tempting.
La Spaziale Vivaldi Mini II. Lots of people online seem to upgrade from an E61 machine to a Vivaldi, so that counts for something
The Mini would be outside my price range, if it were not for a used unit available for not much more than a new Junior DB.
In the end, finding the right deal would probably help with the analysis/paralysis loop I'm in (if you plan to upgrade your machine, especially one of the above, please PM me
I'm using a Baratza Vario, btw, just in case anyone would suggest spending more money on the grinder, and I could not buy a bigger grinder anyway (WAF). But from my experiments, the Vario seems more than capable for any of the machines above.
So, what would you do if you were me? (assume I can justify the budget, even if I'd rather save money).
Thanks in advance for any words of wisdom you can share, Rob
