There are a number of threads offering entry-level buying advice; I found these by searching on "
budget" (title only) as suggested in
forum search tips:
You'll find most recommendations are along these lines:
zin1953 wrote:Now for the machine -- two problems: 1) we as a group often
over-recommend, in that our recommendations often exceed someone's stated budget; 2) that said, a flat $300 budget
is a bit difficult.
Something like the
Gaggia Espresso Pure ($279) might work, but it's very true that the
Gaggia Classic at $399 is a
significantly better machine -- it's $399 and over-budget, but as Tom pointed out, a 20% Bed Bath & Beyond coupon drops the price to $319!
peacecup wrote:I also think a hand grinder and a used Gaggia or Saeco can make very acceptable espresso. I spent the first five years of my espressohood with a Saeco/hand grinder combo that cost less than $200.
hperry wrote:How about a Mypressi Twist, a Kyocera hand grinder and a stovetop steamer? You could get all three for about 300 and make very good espresso. Your milk frothing wouldn't be as good as a commercial machine, but would be OK for the time being. I'm really impressed with the espresso from the Twist and am pulling a couple of shots a day with it.
An important consideration is the grinder. Without a good grinder and freshly roasted coffee, the quality of the beverage is limited independent of the espresso machine you choose. Use the
search page to find plenty of recommendations for low-cost grinders.
