Best $300 or less grinder for my Livia 90?
Postby tims on Wed Dec 22, 2010 2:03 pm
Trying to figure the best $300 or less grinder for my Livia 90 machine. Pasquini wants to sell me the Lux for $300.
Would the Le'Lit, Ascaso or Baratza Preciso be a better purchase?
Thanks for any help.
tims
Postby JonR10 on Wed Dec 22, 2010 2:08 pm
the Pasquini Lux, Ascaso, and Le'Lit all have the same grinding group as far as I know (all have the same burrset and wormdrive adjustment). The Baratza Preciso is a new product developed recently, so I'll bet that it is quite different than the others.
Jon Rosenthal
Houston, Texas
JonR10
Postby another_jim on Wed Dec 22, 2010 2:13 pm
A Nemox Lux grinder without the Pasquini label is around $220. The Lelit and Ascaso are the same burr in a more civilized housing. The Baratza Preciso is new, but the burr it uses is the same as the Virtuoso's, and not all that great for a commercial espresso group.
Update: The Preciso has a newly designed burrset with an improved breaking section (the intake)
another_jim
Postby tims on Wed Dec 22, 2010 4:01 pm
Is the Nemox the one that Pasquini is trying to sell me for $150 that is hard to adjust?
I have a feeling this is it.
tims
Postby mikekarr on Wed Dec 22, 2010 4:15 pm
I have a Nemox Lux and my inlaws do as well and I love it. I prefer the more nuanced flavors to the flat burr grinders I've used. Noisy as all get out though.
LMWDP #235
mikekarr
Postby Eiron on Wed Dec 22, 2010 5:58 pm
another_jim wrote:A Nemox Lux grinder without the Pasquini label is around $220. The Lelit and Ascaso are the same burr in a more civilized housing. ...
You can add the Mini Pro II to the same group for $195.
He's dead, Jim... You grab his tricorder, I'll get his wallet.
Eiron
Postby JonR10 on Wed Dec 22, 2010 7:29 pm
Eiron wrote:You can add the Mini Pro II to the same group for $195.
As far as I can tell, the Mini Pro II and Nemox Lux are stepped grinders.
The Pasquini Lux is the same as the Vanelli's Mini Pro III (both stepless)
Jon Rosenthal
Houston, Texas
JonR10
Postby mikekarr on Wed Dec 22, 2010 9:42 pm
They are stepped. The steps are rather close though, so I tend not to have much trouble dialing in.
LMWDP #235
mikekarr
Postby another_jim on Wed Dec 22, 2010 10:04 pm
The basic Lux is a stepped grinder, but the steps are acceptable. If you intend to use it for espresso plus brewing, the stepped works better; otherwise the the stepless versions are best. If the Pasquini is the larger version, it is the same upgraded build quality as the Lelit and Ascaso, and much more fairly priced.
I have 8 years on and off with this burrset, and it remains my pick for an entry level hobbyist grinder. But warning, this is a noisy and slow grinder, it does great coffee and awful everything else. The upgraded versions are a bit better, but still loud, slow and messy.
another_jim
Postby tims on Thu Dec 23, 2010 11:43 am
That's it! The Mini Pro II. They want $150 for it.
I wonder if I'd be happier spending $300 or so on something in the long run.
Thanks for the help.
tims
Next
Return to Buying Advice
