danaleighton wrote:Based on my experience and usage pattern, I'm not sure I'd recommend one necessarily, but anything that can help maintain a reduced oxygen environment is good, IMO. Doug mentions possible detriments to coffee flavor that might be a product of the vacuum "pulling" CO2 out of the beans. I do not know of any good data on that effect, but there is quite good data on the detrimental effects of oxidation.
Without a doubt, oxidation is one of the chemical reactions which degrades fresh foodstuffs, but the role it plays in coffee staling is not entirely clear, at least not to me.
My take on using consumer vacuum packaging devices is this:
(1) they have no proven benefit in the preservation of coffee, either green or roasted;
(2) they have no proven detriment in the preservation of coffee, either green or roasted;
(3) they do not produce a "real vacuum" nor do they eliminate most all the oxygen that was present, in the way that industrial vacuum packaging devices do. Industrial vacuum packaging devices cost a fortune and are not intended for home use;
(4) fairly rigorous testing on this website (coffee freezing studies) demonstrate very good results, e.g. no detectable difference, between fresh/never frozen and previously frozen roasted coffee when used for espresso. Anecdotal evidence from a huge number of people on this site and elsewhere supports these findings. Given those results, which do not require the use of vacuum packaging, the added value of vacuum packaging is open to question.
(5) extensive anecdotal evidence both from boutique roasters and importers, plus consumers, implies that simple freezing of green coffee without any sort of vacuum preserves green coffee for a long time at a level of quality not seriously below what it was before freezing. Room temperature storage does not accomplish this, although some storage media and methods are better than others. To the extent that vacuums are used in the industry, and seem to have benefit, this is with industrial vacuum equipment, not home devices.
I know of no proven or even accepted value of the use of consumer vacuum packaging in the storage of either green or roasted coffee, that will extend the usable period of storage for said coffees, even though there are a number of people on this site who are enthusiastic about this approach.
ken
